Hi guys,
I have two tri spotlights in my kitchen and one lamp went haywire this week and started to play up. I decided to change it. However, when I started to change it today I realised I had a problem. Basically its an oldish house with the old style wires. 2 red, 2 black and two bare with green sleeve around them. These are not earth wires as they were not connected to anything in the old light, and the new light I just bought is double unsulated.
Anyways, I came to change the light and the two reds were taped together and covered up when the old light was in place. After a bit of research and having no luck at all with the black wires, I decided to free the reds ,join them up and in put them into live. I then joined both the blacks and put them into neutral slot. Hey presto, the light came on but when I tried to turn it off it wouldn't go off.So the crux of the matter is that I get both lights in the kitchen on, and try to turn them off the fuse trips.
Now im led to believe that there is a missing link in the switch wire, casuing this problem. Ive changed the switch as I had a new one in my tool box, but am still getting the same problem. None of the wiring in the switch was any different to the old lights, so am mystified here.
if you can help-please do.
Thanks ever so much,
Lee
Lee
