We pull a tape measure off the last full common rafter.
We drop the tape on both sides of the common so that we can transfer two marks onto the hip blade, i.e. one will be higher up the hip than the other.
We keep a templated section of the bottom birds-mouth and the soffit overhang from previous common cutting.
We measure from the highest mark up the hip down to the outer edge of the wall plate and what will be the crook of the birds-mouth.
We prepare a jack rafter with the correct compound cut done at one end. We then take our measurement and pull the tape from the peak of the compound cut along the side of the rafter and mark off our birds-mouth crook.
We then use our saved templating piece to mark out the birds-mouth, aligning the crook of the b/m with our mark and also pencil around the rafter end soffit/fascia cut also.
You perhaps need to remember also that your seat cut is exactly 90 degrees to your plumb cut.
So if your plumb cut is 30 degrees (which also denotes the roof pitch) then your seat cut is 60 degrees.
You can also position the pitching or pole plate (the vertical wall timber on a lean-to) so that it is under the rafter end and not at the rafter end.
If you do position the pole plate beneath the rafter end, B.C. do like to see the rafters either b/m'd onto it or use something similar to a truss clip to anchor it.
If you were to place a 2" thick piece of timber vertically against that foil insulation and butt it against the rafter then strike a pencil line down the rafter, this would give you the thickness of material you would need to remove in order for your rafter to be the correct length for a butted pole plate..
I mean if a chippy turned up on site and the wall plate was on and the pole plate was up at 30degrees what does he do?? see what im getting at noseall its driving me insane.
[quote="
