Sorting squeaky floor boards
10 Oct 2009
Renfrewshire
My house has real wood flooring over the usual wood floor boards. However its started to squeaky at the door. How can i sort this? I cant get access to underneath and i don't want to lift the real wood flooring...
Robbieee
Sprinkle with talc and brush into gaps, can act as a lubricant and help.
Doorways are often well worn so will be out of level allowing the floor to bow there.
The floorboards re actually real wood tongue and groove. So no gaps between them.
Like this:
Anybody help?
I don't think this would work. The boards are tight up against each other.
Anybody else got any suggestions please?
If it's the original floorboards underneath that are squeaking, how do you think you are going to fix it without getting access to them by removing the flooring that is on top?
Cheers
Richard
Not sure, hence that's why I am asking!!!!!
Wasn't sure if there was a way of doing it from above
That's what I was wondering.... Need to find the joist I suppose
The usual way (or at least, *a* way) to stop squeaky floorboards is to screw them to the joists. So yes, if you can locate a joist, and if you don't mind plugs or screw heads showing in your floor, there's nothing to stop you putting some screws through the lot.
I'm not at all sure how you'd locate a joist, assuming you have no access to under the floor either.
Is living with the squeak an option? All houses of character sqeak somewhere.
Cheers
Richard
