got to be gas wall heaters as mentioned above
so easy to fit and if you dont use the system then no harm will come to them
just run your gas pipe to the correct depth and sixe easy peasy
done something similar for a customer but the heat was for a greenhouse far far away and i used 28 mm pipe in case he upped the usage
