Hi there,
I wonder if someone more knowledgeable could advise me on my issue.
I've just had a gas inspection in my 1 bed flat, equipped with 3 rads and an ancient Baxi bermuda 401 back boiler plus gas firefront, water tank and electric pump. The check has failed, since the gasman found a gas leak, but said he could not find the exact section of pipe that had the escape. He recommended to throw my entire system away and install a new boiler+gas piping, although it has been working with no issues whatsoever. The flat is tenanted and I had no chance of talking to the gasman in person.
- I can't quite understand how come the gas leak is unfixable? It is a tiny flat with very few pipes, none of them running through the floor or ceiling.
- Would you try to patch the existing leak, or go with a new system? Any ideas on the current market cost of a ~25kw boiler+labor?
- I was also advised that they would have to run a new gas pipe through the ceiling, as this is required by the 'new regulations'. Is this true? I see no way to do that as the floor is solid oak glued to chipboard which is impossible to remove without destruction, while top ceiling is just solid concrete.
- Could anyone recommend a no-BS gas engineer in SE London?
Cheers,
Cheers,
