The access to my septic tank is what can only be described as at the bottom of a bomb crater. This crater collects debris, rubbish, leaves etc. I've decided to level the ground up and cover the tank access with a new higher one.
I intend on building a breeze block wall around on all sides. The size will be 6ft (1.8m) x 4ft (1.2m) x 4ft high.
I then intend on bolting on a wooden internal lip to take the new lid of railway sleepers.
My question is with construction using standard breeze block will it be suitable to retain the surrounding soil? Being square and short sides supporting each other at 90deg I think it should be sufficient, but cannot find any information on retaining walls except single length straight walls.
Any info or help appreciated.
