Is it a hard job to cut a trap in a chipboard floating floor to get access to below the insulation again. As it's all held together by tongue and grooves
I assume by floating floor the OP has insulation below so no room for batten.Our house has those horrible T&G chipboard floors so I had to buy a circular hand saw for getting access. I hate the damned thing, it's brutal, noisy, dangerous and frightening. Once the hole is made it's easy enough to re-fit the board by screwing some batten with PVA glue under the edges to create a lip onto which to screw the piece you cut out. This makes it easily removed in future if you need access again.
Router.How do you add a lip?
