Hi guys,
At the moment I have FAN1 setup with a 4 minute timer. I wanted to increase Pa (air pressure) so have decided to throw in a FAN2 with no timer that will run in a serial configuration with FAN1.
I would only like FAN2 to run when the light is on. I would imagine putting L -> L and N -> N without a breaker would cause the fan to running continuously. Should I do FAN1 L -> ROSE S/L instead ?
Also, would I be able to run FAN2 off FAN1 and thereby cause it to run even when the fan is off for as long as FAN1's timer ?
