Recommend a saw for plastic shower panels
21 Nov 2015
Can someone recommend me a hand saw for upvc shower panels.
Ive got a 14tpi Spear & Jackson Predator uPVC saw but its still not gliding through particularly easily on practice off-cuts.
The shower panels seem to be flexing too much. I can probably make do with the predator but if someone knows something better?
The secret is to hold them down really firmly if you can, and then use the hand saw at a very shallow angle, if possible. Consider spraying the cut with WD40 too.
John :)
Cheers mate. Ive used masking tape on it and will try wd40. Its just feels like im ripping through it rather than sawing.
I used to have that problem then I started using the multi cutter which goes through pvc like a hot knife through butter.
I'd try a panel saw. You can get a decent Irwin one for six quid at Screwfix.
Barco do a small saw which has fine teeth and is the best saw I have come across for cutting pvc but if you are going to be cutting pvc a lot then I can recommend buying a multi cutter.
Cheers mate. Iv got a bosch multitool, what blade would you recommend?
They are obviously narrow blades so to cut down the length of a 2400mm panel face-on can't be easy to line up each cut?
Il be doing soffits/fascias come Spring so dont mind investing....
I use the Japanese blades from a company called shark blades they are meant for wood but they work well in plastic too, but if I am cutting any really long lengths then I use the bosch mini circular saw.
For shower panel I used bosch mini circular saw , but found a stanley knife just as effective.[repeated passes along a straight edge.]
For soffit , facia I use chop saw, slow pass with 32 tooth blade.[again stanley knife effective with repeated passes along a straight edge]
With soffit etc most of the cuts are hidden by trim.
