Hi all,
Our heating randomly turns off once or twice a day, usually after it's been on for a few hours. E.g. it's just happened now at 6pm having been on since 3pm. Only realised because the house starts to chill down, then check the stat and it's 2 degrees under temp, rads are cold and the boiler isn't on.
Only way to get the boiler to fire up again is to turn the power to the whole circuit (boiler, programmer, pump etc) off for a few seconds and on again. Resetting just the boiler itself doesn't work, which I hope suggests it isn't the boiler? But what could it be?
We've actually just had the boiler replaced. Had the problem with the old boiler too but more frequent, would have to reset the system 3 or 4 times an evening! Thought the new boiler would sort it but it hasn't, though it is a bit less frequent. Boiler needed replacing anyway as it was a 25 year old Potterton, but I just can't think why this is still happening with the new boiler (Worcester Bosch 24ri).
Any ideas would be much appreciated.
Thanks,
Rob
Thanks,
Rob
