salus wireless intermittently working
3 Feb 2012
Birmingham
Hi, i would be grateful for any help on a problem im having with my salus wireless thermostat. It has been working fine for 2 years. Then 2 nights ago the heating would not go off. I turned temp down on thermostat but it would not turn on heating. I had to switch heating off on boiler.
I then turned the reciever on and off, pressed "reset" on thermostate and the thermostate started working fine for a few hours then same problem. When i reset it and turn receiver on and off its fine for a couple of hours.
Would i be correct in assuming the thermostat or receiver is faulty? Ive tried changing channels by putting pins in different slots but same problem.
Would be grateful for any advise.
I did try new batteries, only changed them 3 weeks ago, but i put in the cheap ones you get from poundland, u know the pack of about 45 batteries for £1. Il try some duracell!
