De Dietrich oven bulb
16 Jun 2006
London
Hi all
A friend has a De Dietrich oven (sorry can't remember the model number). The user manual suggests using rubber gloves to untwist the glass cover for the bulb.
I tried to twist it (anti-clockwise). It just doesn't want to budge. It twists about 5 degrees, but that is it. It does feel as though the rear housing is loose though.
Any (sensible) suggestions?
Had a similar problem with our oven, different make though. I took all the shelves out, and after removing a couple of self-tapper screws, the rear plate of the oven came out to expose the fan and the element. The lamp glass was screwed into this plate, so I was able to "manipulate" it so that it would screw out.
Jimmy
I had another go this morning. I managed to remove the glass cover using a Baby Boa Strap Wrench.
The back plate is slightly loose but the problem seems to have been me being too girlie
