- Joined
- 27 Jan 2008
- Messages
- 23,658
- Reaction score
- 2,664
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
The first system used an under mattress sensor, but the mattress was changed for a firmer one so it stopped working.
It was replaced with a floor level PIR, I questioned this from start as Mother has bad circulation in one leg, the other one is false, and she moves very slowly.
This has now been replaced with a PIR around 1 foot high. It did not even go off with me moving never mind my mother.
Although I know there are loads of units which may work, the second problem is turning them on and off as required. When the alarm goes off it needs some one on the first floor to cancel it, but the even is on the ground floor so step one is see what is wrong, then step two is correct, step three is cancel the alarm which may have been going for 1/2 an hour before we are in a position to cancel it.
For the door sensors we use a simple time switch, they are only active 9:15 p.m. to 7:45 a.m. that's OK, but bed sensor is together with wrist pendent so can't switch it off, OK when sensed the bed, but putting cloths away in the room sets off the alarm.
At the moment I put a oven glove over the PIR in the day, but problem is too easy to forget to remove it at night. What I really need is a local reset switch. I tried using a plug in remote switch, but again problem is when it is not reactivated. So what is really needed is a timed switch which can be pushed to cancel and inhibit for 15 minutes so when it goes off I can cancel and inhibit local to sensor.
Hard wired I could do it, I have a couple of spare PLC's I could easy write a program, but it's not hard wired it's all RF linked. Still have not tried using other RF equipment not sure if that would set off the devices.
Since mother is in a wheel chair any reset switch at 6 foot is out of her reach.
In the main when the alarm goes off, all I do is monitor, I watch to see all is OK, only if some thing goes wrong do I jump in and rescue.
So it's now at a stage where if I can fit an alarm myself then to heck with cost, at least I get a good nights sleep, but although an intruder alarm will likely work, they are not designed to be local reset or auto reset.
If the alarm auto reset after 5 minutes that would be OK, but better if local reset.
So open for ideas, does not need to be secure, but not really looking forward to hard wired system, RF does seem easy option.
