I don't know if this tells us anything, but if I have a device with a heat coil - like a fan heater or a paint stripper gun - plugged in at the time the fault occurs, it makes a bit of a loud pop and a brief flash from the fan/gun. Gives me a fright. Don't know if that's just normal because the power was interrupted or if it indicates something...
Sounds significant to me. I would expect a fan heater to simply slow down and stop if the power were to go away.
Are you saying you've seen this from multiple "heat coil" devices?
