clio petrol filter
7 Feb 2011
Sussex
I need to change the filter on a Renault clio 1.2 16valve 03 plate have been told its part of the petrol pump but cant find any reference to the filter in the Haynes manual my local car parts motor factors say there is a filter available for the model against the registration id any help with this please
yeah but at what point does the petrol get filtered to keep out any crud and where is it someone said it was on the offside behind the wheel arch liner!!
Follow the lines from the tank. If you can't see an inline filter, it's an internal one. Leave alone!
problem is having started up fine it cuts out then after a while it starts ok and seems fine for a while then its back again and can take ages to get it started I previously fitted a new coil pack and plugs and the engine is in fairly good condition
