Caple tumble dryer spare part - pulling my hair out!
1 Jan 2010
London
Hi All,
I have a Caple Tdi 110 integrated tumble dryer. The three arm spider bracket which mounts the bearing to the drum has broken and I've managed to remove it by drilling out the 3 retaining rivets.
The problem is I'm unable to locate a replacement spider bracket. Has anyone else had this issue or can you point me in the right direction.
Cheers
Daz
Try White Knight part no. 421309205591 see if thats what your looking for.
Thanks but what I need in addition to that is the 3 arm bracket which mounts on to the back of the drum.
I don't think it is available anymore as a seperate item only with a new drum.
Any chance you can repair the bracket (e.g splint, weld)?
