Hi
I have a Baxi Solo 18 and I bought a Nest Thermostatic controller thinking that the wiring would be obvious but the PCB Diagram in the manual doesn't show the information that I need.
I need to know the Live, Neutral and CH pins on the connectors - or a more detailed Wiring diagram so that I can work it out for myself. AS you can see below - the unused pins are not labelled in the diagram...
http://library.plumbase.co.uk/flipbooks/RE/baso18he_22211_t/baso18he_22211_t.html#p=36
Kevin
Kevin
