Can someone please help with this?
My Ideal ISAR HE 30 Boiler has got a couple of minor water leaks, one from the pump 'flange' where it joins onto the body of whatever it is behind it (excuse my lack of pro knowledge) which is evident only by the scale that has built up around the 'flange'. Second even slower leak is from the bottom of the heat exchanger where a black circular plastic type fitting joins onto the exchanger.
Two gas engineers have diagnosed the same causes and said the gaskets on both need to be replaced which they could do, but for two weeks now they both say they are waiting for prices etc for the gaskets.
My local Plumb Centre tell me that these gaskets do not show on their parts list.
Does anyone know if these are available or is there another way to stop these leaks with LS sealant or the like?
Is this job too problematic too small for a gas engineer?
Pro advice would be appreciated.
Thanks, Mick
Thanks, Mick
