Hello,
I am having installed a new oven 2.3kw and induction hob 7.2kw. This is on a dedicated 6mm t+e radial circuit with a 32amp breaker. There is a 45amp cooker switch with socket above worktop and a cooker connection unit behind the oven. There is already a cable attached to the new hob but not for the oven. Which cable and size is neccasary for the oven. Also does the whole circuit sound usual.
