Parents boiler wasn't firing. ( I know who wants the heating on in this weather!). Pump appeared to be not working. I done some searches on here and carried out a test on it with a digital multimeter. I understand I should have had a reading of 120 to 200 ohms . Nothing like so I pronounced the pump dead but before signing the death certificate I applied 240 volts direct to the pump and it started up. Now I'm not so sure. It did get really hot in a short space of time without any hot water flowing through it. Any advice you guys can give on this. Would a pump that failed the multimeter test still be able to start up?
