I'm having a patio built, which includes a water feature and some lights. Both the water feature pump and the lights are 240V. The builder has wired these using black 3-core flex, run to the house in plastic ducting. This ducting runs under a flowerbed, then about 10cm below ground level immediately next to a wall, then under a bit of patio just beneath the flags and the sand they sit on. The cable emerges from the duct by the wall of the house, and I believe it is the builder's intention to run it up the wall outside the house, then drill through the wall and connect it to the back of a plug socket inside. I don't know whether he intends to use an FCU or not.
Is this all generally OK? From reading on here I was half expecting to need an armoured cable, buried x deep, with warning tape above etc. etc., but maybe that is just for supplies to garages/sheds?
