Laminate flooring over concrete / wood
9 Dec 2011
Down
Redoing the kitchen and it is part concrete and part chipboard floor.
The floors are level with each other, but the chipboard side has a slight bit of movement along the join, about 4mm if I'm bouncing myself on the edge of it, in normal day to day I wouldn't be bouncing right on the edge !
We are going to use laminate on the floor. Do you think boarding across this will be an issue with 8mm laminate and decent underlay ?
Cheers !
Mark
As long as it goes at 90 degrees to the join, it'll be fine, if it runs parallel, then there might be an issue; you'd need to make sure that the centre of the board was directly over the join.
Thanks for the reply. If the centre of a board is over the join then is the adjacent boards edge not going to be at it ?
There's a slight run downward on the chip side also now I've noticed
You'd need to do a bit of carefull planning keep edges off of the gap, but they'd still be supported by the boards either side, so you should bo okay. You could use some 2 part body filler to create a feather edge slope on top of the chipboard. It won't be perfect as there's a bit of spring under the edge, but hopefully, even if it cracks underneath, it shouls still proved a degree of support.
Cheers for the reply. Just seen some click laminate, think it may solve all my problems !
