Karcher K2 leaking
5 Jan 2010
Norfolk
Karcher K2 leaking.
I have stripped this down, the motor and valves are in a two part plastic type case.
no screws holding it together, series of plastic clips both sides,
but unable to see a way of releasing these to access the parts inside,
anybody over come this problem I have, appreciate any help. thanks
They are not meant to be repaired. Buy a new one. Better still don't buy a Karcher there are much cheaper ones on the market that do the job just as well and will last, at least, as long as a Karcher.
Can't believe these cannot be repaired. I'm sure somebody on here has repaired a Karcher
Plenty of tips on you tube for the K2 but not how to get to this leak.
Last one I looked at I couldn't get apart. Why do you think Karcher, or any other manufacturer for that matter, would make them repairable. They are built, like most things these days, to last the mandatory guarantee period. After that the manufacturers want you to buy a new one. They don't make money doing guarantee repairs and if you do manage to buy any spares from them they charge stupid prices.
Found a way to unclip the two part case, so now valves are viable, next step connect water and see where leak is coming from , strip and rewasher/seals.
Looks like the owner did not protect from freezing, when stripped found body split.
