Cut through boiler cable next to the watertank.
25 Dec 2017
Anyone, please advise what I may have damaged
I was cutting screws under the skirting board next to the water tank airing cupboard to find myself cutting through the blue wire of the 4 core 1mm cable, this tripped the boiler 3amp fuse and the boiler cut off.
I replaced the cable but now the boiler light is solid red. Lockout mode. I can confirm I have double check the wiring and everything is as it was before and terminated correctly.
I fear I have damaged part of something.
What could I have missed or done.
Before I get an engineer out us there anything I can do?
You don't give any details of your boiler, but some reset automatically after a lockout, some have to be manually reset. It sounds that yours may be the latter. Check your boiler manual for details of how to reset it manually.
Hi
Its a potterton suprima 30 40 or 50
I have held the reset button for 10 seconds. It then goes orange then stays flashing red (flashes red 5 times repeatedly)
I then hold the reset button for 5 seconds, it goes back to solid red. Lockout.
Hmm. Usually suggests a problem with the overheat. Turn the thermostat knob to minimum / off. The lockout light should go out. Now turn it back up and the boiler should fire up.
I do wonder if this could have damaged a component on a circuit board or blew the pump somehow?
I would be great if nothing was damaged but I can't clear the lockout for some reason
Hi Stem
I will be calling the boiler engineers shortly.
One thing that I'm not sure about.
Is seems the fuse was blown from a small nick in the blue wire (return from pump), is this possible?
A fuse blows when an electric current exceeding the rating of the fuse flows through it. To achieve this you would have needed to create a 'live to neutral' or 'live to earth' short circuit.
A live to neutral short circuit would occur for example if you had made contact between a live conductor and neutral conductor. With heating system wiring, a blue wire is not always used as a neutral, sometimes it is used as a live conductor.
A live to earth short circuit would occur for example if you had made contact between a live conductor and earth conductor, or live conductor and an earthed object such as a power tool, or metal pipes.
Just making a "nick" in a single cable without making contact with anything else wouldn't blow a fuse, as no current would flow.
Also, you sure that you have remade all of the connections correctly? The pump only has L, N & E connections, so doesn't require a 4 core cable.
Oooh be careful, you will get into trouble for suggesting that the OP starts tinkering with his boiler internals.
My only comment on your otherwise excellent post is that in this case the blade of the cutter may well have been earthed through the mains lead. Not all are II equipment, so cutting into a live conductor would create a live to earth short.
Edit: of course I did just assume the OP was using a mains powered cutter rather than a hacksaw!
Also the op should confirm the other core isn't used for something else eg tank thermostat or zone valve.
