The lighter socket in my wife's Fabia is permanent live and she forgets to disconect the dash cam. Before i pay money out to have it hardwired, is there an easy fix like a fuse swap? thanks for your help in advance.
thanks for the info but i meant something i could do simply. had it been an old car i would have a go but, i don't want to mess with a brand new car! lol
If there are unused fuse spaces in the fusebox you can make a fused bridge to convert it to only on with the ignition.
This only works if one of your spare fuse holders is switched when the ignition is on and is rated for the correct current, otherwise you'll have to use a lower fuse value. For example, if the car doesn't have heated seats, but there is a spare fuse holder for it, you'll likely find that it only comes on with the ignition, so you bridge across from that fuse holder to the cigarette fuse holder.
My Fabia is an old lady now (2003) and has exactly the same situation, so it looks like this is a long-standing thing. I have the same problem, but have just become habitually aware of the need to 'pull the plug' when I stop the car. To be honest, it's no real hardship and becomes and automatic thing. Perhaps you needn't go to any trouble after all. Actually, I'm scrapping it in a couple of weeks anyway.
Anyway, in answer to your question, I have seen videos of how to hard wire a dash cam and it doesn't seem a difficult job at all.
Sorry. I've just noticed that someone else posted something very similar. Still, you have two slightly different approaches to learn from!
My Fabia is an old lady now (2003) and has exactly the same situation, so it looks like this is a long-standing thing. I have the same problem, but have just become habitually aware of the need to 'pull the plug' when I stop the car. To be honest, it's no real hardship and becomes and automatic thing. !
Pull the plug - like using a choke on an old car once learned never forgotten. Well at least it won't hurt your leg like if you forget to ****** the mag. on a Brit single motorcycle
