I’m trying to get compression fittings to securely attach to my Webpro WF100 cable. I’m currently using the compression fittings that were supplied with the compression tool itself and having a practice.
I’m hoping it’s the compression fittings that are not gripping correctly but maybe I’m doing it wrong. Have followed a few guides on how to cut the cable correctly but when I eventually get around to compressing the connector onto the cable, it isn’t completely secure as I can pull the cable away (with some force) from the connector.
Here are some pics and the final pic is after I have pulled the cable off - it looks like they are gripping onto the cable but not by much. Are there different sizes of fixings for certain cables or maybe they are cheap and don’t grip as well?
