Hi
I am looking for some advice on my guttering.
I have recently replaced my slate roof. I am no expert but I think the roofer did an OK job on it. I do not think was the guttering was a good job though.
I now have damp. Ironically I had never had a leak or damp in the house until I had the roof replaced! Anyway I told him about the damp that I was getting in the corner of the house and he just put a load of sand cement in the corner where the guttering meets the side of the house? He also drilled a hole in my sandstone coins to hold the gutter and smashed it rather than drill into the render between the bricks 4 inches higher but that’s another story.
The original guttering ,channelled water from the main roof straight into a soak. The roofer explained that this was not needed
This is where the original pipe was that led to the soak...excuse the mess...I work full time and have a young family.
[/IMG]
[/IMG]
so he left the pipe disconnected and now has the whole side of the roof is draining straight through a gutter pipe onto the top of another lean to roof, down the slate roof and then along a gutter (instead on piped straight into the soak).
Where the roof drains onto the lean to and then into a gutter (where the cement was bodged in) I am getting very damp walls.
I just think that this section of the gutter is overwhelmed by the amount of water from this whole side of the roof. I have cleaned out the guttering and disconnected the pipe so that the water can exit as fast as possible but I am still getting lots of damp.
So I think I need to put it back to how it was so I think I need to buy some straight lengths of guttering and some elbows to connect back up to the soak. I need help on the type of offset for the elbows and connectors to buy?
Do you think my theory is right about the amount of water that is hitting that corner?
Any useful advice on how to tackle this gratefully received!
