I am having problems with my vaillant 937 ecotec boiler, approx 7 years old
It will not give any hot water or heating and comes up with error code f.75 which says is the pressure sensor switch or pump.
I can hear a low rumble noise from the pump also clicking as if to work and have changed the pressure sensor switch for a new one, but still not working.
Have googled to see what else it could be. Someone has mentioned about the expansion vessel, I have deflated the vessel which blew out air fast at first then little dribble of water came out. when re pressurising the vessel at 1 bar the boiler will fire up but the temperature will shoot over 100 degrees and the pressure gauge rapidly goes up to 3 bar and shuts boiler down, not all the time though, i can also get it to fire up like this by opening the filler loop to 2 bar, then does same again with temperature and pressure.
Any help appreciated
