Bit of a specific problem here, so any help appreciated.
I have a waste disposal unit plumbed in under the sink. A quooker outlet pipe (marked C in the diagram) connects to the waste pipe (above the u-bend), which is also fed into by the waste disposal unit.
The problem I keep having is that mulched up food waste is spraying out of the quooker outlet pipe.
It's not happening every time I use it. But every so often, whenever I look under the sink, i'll see food waste has sprayed everywhere.
I'm assured it's been fitted correctly.
any ideas?
any ideas?
