Very old Anglican door removal
29 Dec 2009
Staffordshire
Hi All,
Posting on behalf of my Dad.
He has an aluminium(i think) sliding door, from Anglican probably 30 years ago. The door itself is fine but the runners/rollers are broken. He has contacted Anglican but they obviously don't sell this door anymore and can't track down much information about it.
We believe we should be able to raise each individual door up by the screws on the side, and it should lift out BUT it is too high and does not clear the top and was possibly made too big, so we can't get that to work.
We're pretty sure if we take the whole frame out we can fix it that way, but are trying to save doing that unless we really have to.
Anyone have any suggestions please, i've posted a few photos in case it helps. Thanks
fQjaZy
gGQSgd
cGmdnJ
ijnhgd
i5XF1d
dDBa1d
Not sure if images above work but uploaded them and copied pasted from:
https://ibb.co/fQjaZy
https://ibb.co/gGQSgd
https://ibb.co/cGmdnJ
https://ibb.co/ijnhgd
https://ibb.co/i5XF1d
https://ibb.co/dDBa1d
Them doors have a habit of failing and can be a cassocks of a job to rectify :!:
Now I might be totally talking out my ar$e but I'm fairly certain if you remove the frame screws along the top aluminium section either the front half of the aluminium frame will come forward allowing the top of the door to be lent forwards, slide the door closed to expose the screws then open to expose more, careful because the doors are very likely to have 6mm glass in and will be heavy
Should lift out easily. Put the door in its most open position (to avoid any anti lift blocks) and lift it fully.
Its possible the top of the track has bowed down a bit in the middle which might make it tough
