- Joined
- 26 Dec 2012
- Messages
- 117
- Reaction score
- 8
- Country
Hi!
This weekend my son had a problem with a leaking tap tail in his bathroom. I "fixed" it by replacing the entire tap and tails (the whole lot was old and grotty) but I also had some issues with the isolation vales so ended up replacing those too.
To do that I drained the system; turned the mains off and turned all taps on until no water flowed from hot or cold.
Tap replaced, water on, check for leaks on the cold. All looking good until the hot tank filled up. We get barely a trickle from any of the hot taps (there are only three; kitchen, bathroom sink and bath.)
At first I thought it was just air so opened all of the taps. Quite a bit of gurgling which eventually stops but no change to the flow. Left them open for hours and no change.
I checked the header tank; all clean and no sludge. And left all the hot taps open for three or four hours. If anything it's even worse now. Just a reduced flow when the pipes are full, but only a trickle once any one (or all) have been on for any length of time.
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
