Dripping wall mounted tap.. can't see how to access washer
8 Nov 2004
Hello all
I have a dripping hot tap in a bathroom. Hard water area so am guessing limescale.
View media item 101747
I can't see how to open up the tap to have a look.
I was expecting an allen key screw underneath somewhere to enable the housing to be removed, but there isn't one there.
The tap is solid - I can't pull it "forward" to expose more tap. There is a fascia ring thing which comes off easily (is removed on left(hot) tap in pic), and (EDIT) I have been able to get the rear most sleeve unscrewed but it doesn't help me.
View media item 101748
I think they are from about 2004 ish.
Any ideas?
Many thanks
buckmoy,taps vary so is there is there a possibility of some clear focused photos of the tap,showing top,sides,front and the backside :cry:
other info request is .do you have tools to do basic plumbing repairs :?:
:LOL:
There are no pictures.
Add some by copy/paste into the reply box, or drag them into the reply box.
Oh. There are pictures (and there were some in the first post - @Old&Cold 's first reply now makes sense if they aren't visible). I can see them on the desktop / chrome version of the forum but not on my iphone... will try and see if I can fix pic view
Hopefully below now are some pictures (used drag and drop instead of forum's media function)
OK. Think I may have a problem.. parts A and B in the pic below both unscrew. If I unscrew B only, I get to see C, which looks to the cartridge. Problem is, gap to access is only about 1mm when B is horizontal (in pic below B is tilted forwards by as much as it will go, exposes about 3mm)
Any ideas other than cut off B?
Or get super thin spanner (looks to be about 18mm?)
