Hi All,
First time post so apologies if i'm straight in there begging for help.
I've just ordered the "Heating and Water" version of the hive instead of the single channel - all my own fault, got excited and hit the buy it now button on the Currys ebay site.
Literally realised as soon as I placed it so emailed Currys, they cant cancel the order or change it to a single channel one, I have to refuse delivery and once they have it back, they will refund within 14 days....wont even exchange in store (again, fine, my own fault - seems silly though)
My question is this, from what I have read you can indeed use the dual channel receiver, but only if the boiler uses 230v switches - is that right?
My Boiler is a Vokera Unica HE 28, wiring is attached.
It does indeed say 230v at the main power terminals, but not above the clock / thermostat terminals.
Can it be done on this boiler? Last thing I want to do it pop it!
I know on the single channel, id simply connect up common and 3 (heat on) but on the dual channel there is no common, and Id be connecting to terminal 4 (if it were possible).
Help!
Help!
