New switched spur off the ground
My, how you have changed.
Perhaps it would be quicker if you showed where such things are mandatory and where the Building Control were correct in insisting that such a self-builder were not correct in his demand that mere guidance may be ignored.
Is this similar to Part F which merely states:
and some have translated this to mean that fans in bathrooms are compulsory because someone else said so?
¿Que?
Why on earth do you say that?
I think you are missing the point.
You said "if someone were having a house built for themselves then it is up to them."
Compliance with Part M is not up to them - even if they are literally self-building with their own hands and intend to live in the house until they die, they have to comply with Part M.
As for guidance vs mandatory, all I have done is to question the wisdom IRL, if compliance with Part M is compulsory, of getting into a fight with Building Control over the heights of accessories.
Apart from if they do apply, the stupidity of going toe-to-toe with Building Control over such a trivial matter.
But if you're building a house, how much of an enemy would you want to make of Building Control over guidance vs actual mandatory requirements?
If someone was a "self-builder" but the work was physically being done by architects and/or contractors and/or there was a professional project manager, I wonder how much extra you would advise them to pay in professional fees, and how long to hold up the build for, in order that there could be an argument with BC about the enforceability of guidance for things like accessory heights and fans in bathrooms?
That's not a rhetorical question, BTW - if you disagree with the idea that the most sensible thing might be for someone to just go with the Approved Document flow then your position must be that they should always stand their ground. Which could so easily have cost implications. So how much would you advise them to spend on that dispute?
Well, you used not to like officials who overstepped their remit, and
you used to be a stickler for what the regulations actually said.
Obviously not worth it IF compulsory but did you not agree the heights were only a recommendation?
The Approved Documents are merely guidance (apart from the quoted actual Building Regulations) are they not?
I still don't, and I still am.
All I have done is to question the wisdom IRL, if compliance with Part M is compulsory, of getting into a fight with Building Control over the heights of accessories.
They are, but Part M isn't. All I have done is to question the wisdom IRL, if compliance with Part M is compulsory, of getting into a fight with Building Control over the heights of accessories.
They are. But all I have done is to question the wisdom IRL, if compliance with Part M is compulsory, of getting into a fight with Building Control over the heights of accessories.
If someone found that Building Control were insisting on something that was only guidance, how much would you advise them to spend disputing it?
Ok, maybe not wise - perhaps not worth it might be more accurate.
Part M does not mention heights of sockets and switches.
It is, like all the other parts, quite vague -
then, as usual, someone else describes what they think is reasonable.
Unwise, not worth it - pretty much the same.
I know.
But if you think it's not worth arguing the toss with BC over it I'm puzzled about why you've written all your recent posts just because I talked about the stupidity of going toe-to-toe with Building Control over such a trivial matter.
Yes, I did
In reply to
I am not saying I would refuse on principle but if someone were having a house built for themselves then it is up to them.
If someone is having a house built then Part M does apply to them, and it is not up to them whether they comply with M1.
