Admin/Moderator, look at the link below what is in the public domain. The persons name in question is on the "Information" tab of their DiyNot Profile, not to mention the "Home Page" link listed on the page linked below goes to their personal website (what also contains their real name) what in turn links to their YouTube Channel!
Eveares, please stop using "what" when "that" is the correct word.
I don't mean to be a pedant, but it really does make you appear to be far less intelligent than you have already proved to be.
To post those as a link to justify removing a post is surely embarrassing for whoever wrote them and certainly not productive?
Agree, I suspect that the moderators have as little information about their job as i have gleaned from reading the rules linked above. So I'm not sure you can blame them for struggling! Blame the system not the playerWhat I am struggling to grasp or comprehend is why it is not acceptable to post a members name in response to a question, when not only can that be found out from their profile page, but in addition it is very likley that their name has been mention on other DiyNot threads in the past (
I think the French use plug sockets, where on the wall the line and neutral are sockets but earth is a pin sticking out
Re the Video:-Well, I suppose those who use the term would probably say that a "plug socket" is a socket designed to accommodate a plug (i.e. have a plug inserted into it), rather than to accommodate the head of a bolt or a nut, a piece of drainage pipe, the stump of an amputated limb or anything else !
At least it can be argued that it makes 'some sense' - which is more than one can say for 'plug top'!
Kind REgards, John
Maybe, but even that introduces some uncertainties/ambiguities, since some use "socket outlet" to refer to the actual "outlet" - such that a "1-gang socket" ("single socket") has one "socket outlet" and a "2-gang socket" ("double socket") has two "socket outlets".It seems that the term now preferred by manufactures (and others) is "Socket Outlet"
Rules don't have to make sense.What I am struggling to grasp or comprehend is why it is not acceptable to post a members name in response to a question
Indeed - and I presume that such is part of the training of those who create rulesRules don't have to make sense.
I seem to remember any socket with a device be it a filter, a RCD or any other made by MK is rated 13A per unit, but those with are simple double sockets are 13A per socket.Maybe, but even that introduces some uncertainties/ambiguities, since some use "socket outlet" to refer to the actual "outlet" - such that a "1-gang socket" ("single socket") has one "socket outlet" and a "2-gang socket" ("double socket") has two "socket outlets".
This has caused ongoing arguments about the current 'rating' of MK double sockets. Their documentation indicates that (other than 3-gang ones, which are fused for 13A total) their sockets are 'rated' at "13A per socket outlet" - and, despite my attempts to get definitive answers from them, there is still discussion/debate/argument about what the rating of one of their 2-gang sockets actually is.
Kind Regards, John
Well, you may 'remember' that from somewhere, but it's more than the various MK tech support people I've spoken to have been able to tell me.I seem to remember any socket with a device be it a filter, a RCD or any other made by MK is rated 13A per unit, but those with are simple double sockets are 13A per socket.
