Building a shed which will be 50m from meter in the house. Will have 3 double sockets and 2 lights. Not to be used for anything heavy apart from occasional use of an industrial sewing machine.
Looking to have a rcd protected cu in shed: something like this
https://www.screwfix.com/p/british-general-5-module-3-way-populated-garage-consumer-unit/1926g
Will lay 6mm swa cable at a depth of 500m under lawn and ideally would like it connected directly to fused switch which was initially used for economy 7 cu that is now obsolete.
Will do all the manual work myself to save costs, with the electrician doing the connections at both ends. Will this be ok, connecting directly to fused switch?
