- Joined
- 14 Mar 2019
- Messages
- 39
- Reaction score
- 1
- Country
Not very nice. Those blue and brown wires should be hooked around clips within the ceiling rose, and short enough that none of the blue/brown (only the white sheathing) can be seen from below. As things are, it's quite probable that they are not 'hooked' and therefore the weight of the bulb/lamp will be trying to tug the end of the wires out of their terminals.When I was putting a light shade up, I noticed the blue and brown wire at the base of the light fitting are exposed. Is this anything to worry about? And how would I fix it? Thanks!
Thanks. I can switch off the power at the fuse box then unscrew the rose. Doing this (and, if needs-be, hooking the cores) is ok to do without any special kit?
This is under the cover. Unless I'm missing something, there aren't hooks here?
