Hi
I'm having a bit of a head scratching moment on something that seems v simple yet I can't seem to figure out.
I'm attempting to use an arduino device with SIM card to shoot off SMS msgs when a digicom output triggers.
Digicom 1: is set to output group Area and 00 - Alarm
Digicom 2: is set to output group System and 01 - Mains Power Off
I then tested the outputs under eng utilities triggering Digicom 1 on and then off, same again for #2. Under test these worked fine and I received the sms msg.
I thought it was all working until a user accidentally triggered the alarm a while after but no SMS was received. I went and switched off mains power to see what would happen and again no SMS.
I redid the eng utility test on the digicom outputs and these work perfectly under test.
I can't figure out why it works on test but doesn't trigger the SMS when it really needs to.
Am I missing some other programming on the system to make it work?
I'm on v2.11 (until I buy a flasher unit!)
