anyone come across this? we had a "safedoors" composite door fitted last week, perfect initially but within a few hours we couldn't lock/unlock without difficulty, having to push it back into the frame to allow it at all. the company that fitted came and had a look, it wasn't as bad by that time but he said they didn't quite understand it, but the top and bottom of the door seemed to be bowing one way (into the house) and the frame the opposite way, he adjusted the keeps and said they would return today. over the weekend it has been fine.
it's the kind of arrangement where the door has a window as part of the frame next to it.
the door is west facing, so as soon as the sun finally came out today, hitting the door, sure enough the problem has returned. I did some measurements using shims and a laser thermometer
cold
(inside temp 18 top 19.5 bottom)
(outside temp 16 top 18 bottom)
shims show the door comes inside by 3mm at the top and 3mm at the bottom relative to the frame, the lock part of the door in the middle is flush with the frame.
hot
(inside temp 23.4 top and 27 bottom)
(outside temp 27 top and 43 bottom!)
shims show the top is now 4 to 5 mm away from flush and the bottom is 7 to 8mm away from flush with the frame!
now, the door is inset within an open porch, so it seems the sun is hitting the bottom at full whack, but the roof is shading part of the top, this is causing uneven warping! as soon as the sun goes in, the temp drops and the door returns to the better position.
Has anyone experienced this?
Is there any remedy to this? We have neighbours with almost the same position, they have a pvc rather than composite door and we don't think they have this issue, would pvc be the only option? our original was wood.
The door was measured up by the company so I would expect any such issues would be checked during the survey.
We haven't paid anything yet
cold
hot
