Just a quickie. If you are studding out a single skin garage and you have block, breather membrane, studs from out to in. Which way should the printed side of the breather membrane be?
I would think facing outward to stop any water that gets through the block from penetrating the timber but would allow moisture out if any got into the timber side.
Does it matter which way round it goes?
Sound correct?
Sound correct?
