Warped front door - adjust frame with shims?
7 Sep 2006
London
Very old (100+y) front door is warped - top corner on lock side is about 12mm away from frame, letting in draught and noise. I don't want to replace the door, so I'm thinking of building up the frame enough to use weatherstrip. What would be a long lasting way to do this? I thought about building a shim out of multiple layers of veneer - it needs to be about 10mm gradually thinning to nothing over about 1m. I could pin and glue it, then use wood filler to smooth over. Alternatively I could 3d print a shim in sections, but I'm not sure the material would be that strong.
If the door is warped, could you build up the door stop instead?
Building up the face of the door might look unsightly.
Or do you mean the gap is between the side of the door and the frame?
Blup
I did mean build up the door stop, sorry, didn't know the correct term.
What do you think of my ideas for doing it? Would it be better just to buy several thicknesses of foam weatherseal?
How big a flat is there on the door stop part of the frame.
If its big enough, buy some small battens, say 25mm x 10mm -stick draught seal to the edge, push up to shut door, slightly compress seal and pin in place.
About 10mm, but the warping means big gap at the top, fading to none at the bottom - I need a fading profile. I've bought some very thin adhesive foam, I'll try layering it.
search for nail on excluder or fit a bolt to pull it in when your home?
