Bosch Self Cleaning Condenser -Condensor Sensor Error E14/E00!
11 Jun 2019
Sweden
I have a Bosch Self Cleaning Condenser Dryer WTY88888SN that runs "fine" but laundry doesn't get dry. Have to run a few cycles and still not totally dry. No error or so!
I have gotten E14 sometimes in the past but usually after restarting/pulling plug it works fine again.
I have found out how to make a component test and when I test "condensor sensor" I get E14, beeping and contact service. Then need to restart machine.
When I get back into component test it says last error E00
The machine will then run fine again outside test. I mean without errors but still not dry.
Any help highly appreciated!
Br,
Peter
Is there any water collecting in the reservoir at all?
Is the machine heating up?
There is much less water than before but some I would say.
It is heating up.
Thanks for your response!
Br,
Peter
Hello! Did you solve your problem with your Bosch dryer? I think I have the same problem as you did but my technicians cannot tell me what is wrong with my 6 serie Bosch dryer...
I know it's been years ago but your post it's the only one who describe my problem most accurate.
Thanks!
