When working as a tunnel boring machine electrician in Hong Kong I took a 40 foot container and fitted a curtain down the centre and a air conditioning unit and a wall mounted fan heater, the fan circulated the hot air which at end of circle when past the AC which removed the moisture it had gathered, the was a continuous stream of water from the AC and it would dry 20 pairs soaking overalls in 4 hours. Likely would have dried more but at time only 20 workers on sight. Until I set that up it was impossible to dry them in 8 hours hanging under cover but in open air.
The problem was humidity, you can hang your washing out protected from rain but still getting wind in a carport, and with even 75% humidity they will dry, but in 95% humidity not a chance. Oddly they will also not dry in nearly zero humidity, once air is before freezing moisture drops out so it is very dry, but once garment is frozen the water stays there. So in the winter the carport will not work for drying.
So using a tumble dryer is likely using far less energy than my drying room, and one only needs one deposit of bird lime and they need washing all over again, same with neighbours BBQ.
However I am still uncertain as to if there is some item switched on using power? The plug in power meter is great, I can see what my TV set up uses,
View attachment 166017 I can see the SkyQ, TV, and Blueray box use 26 watt on standby and 87 watt while watching, as to why it reduced to 9 watt then at 6 am returned to using 26 watt unknown.
But each plug in item can be monitored,
View attachment 166018 chest freezer shows how often the motor cuts in and how much power is used, however a meter on the whole supply does show me in living room when tumble drier and washer complete down below, but under 0.5 kW it is hard to work out what has started to run, central heating pump is 100W so hard to see when it has started and stopped when so many other items also use around the 100 watt.
The chance I would realise if a bathroom fan was left on, or loft light left on is slim.
