The plaster said I should PVA the edge of the new plaster where it meets the old.Thanks
Yes, before the new plaster is plastered, maybe? I'm not a good plasterer or a good decorator, but before plastering a bare wall it would always be wetted, and sometimes a watery mix of PVA brushed on. Not sure what the OP's problem is exactly, more info would be good.
I used a mist coat 50/50 & have used a brush for first coat, I pleased with the result so far.
Hopefully you will be ok but in spite of what you have read on the web, you shouldn't be diluting emulsion that much.
If the paint manufacturer recommends a 5 to 1 mix, I am more inclined to believe them than someone on the internet who clearly isn't a professional decorator.
Not sure why some people ask here then completely ignore professional advice!
