- Joined
- 6 Nov 2008
- Messages
- 818
- Reaction score
- 12
- Country
its it acceptable to fit a gutter downpipe into an aco drain?
As long as the Aco is connected to something that will drain rainwater.its it acceptable to fit a gutter downpipe into an aco drain?
The groundAs long as the Aco is connected to something that will drain rainwater.
The amount of Acos I have seen cunningly draining into the square root of feckall, is astonishing. Sometimes the 'ground' needs to be defined Woods.The ground
If it gets through planning at the end of the new drive, then that's all that matters.The amount of Acos I have seen cunningly draining into the square root of feckall, is astonishing. Sometimes the 'ground' needs to be defined Woods.
theres a new block driveway going in along my street at the moment.The amount of Acos I have seen cunningly draining into the square root of feckall, is astonishing. Sometimes the 'ground' needs to be defined Woods.
as long as it is a surface water drainYeah it goes into a drain
But a S/W drain not a soakaway ? Like er- mine does, but we're only 100 yds from a river Whole estate has separate S/Was long as it is a surface water drain
The drain going to a soakaway is a surface water drain don't understand what you are saying.But a S/W drain not a soakaway ?
