UPDATE: after much troubleshooting I tracked down the smoke detector that has the power feed coming into it. I then did some further detection and found the FCU which had a blown switch! Replaced this and “most” of the detectors now have a green light.
Issues now:
1. 1 of the detectors has a green and red light and the test function does not work
2. 1 of the detectors has a green light but the test function does not work
3. Most significantly none of them are interconnected. I tested two which are wired in series but they still don’t sound together.
Thanks for your help to date.
Issues now:
