Scantronic 9448+ Alarm
Now then! I've managed to set it all up. I've managed to change the user code etc. Now though I'm getting a tamper light on when I turn the panel on. I put my user code in to stop the internal sounder. Then I get a light on number 2. Then when I put the code in again it goes to tamper light. Would this indicate the tamper on the pir that I have wired into zone 2 is faulty?
I've taken the tamper wires out from the panel and linked the AT Connection with a short wire. But it's still going to tamper. I've also shorted out the 0v and TR connections too just to make sure it's not the box outside making the tamper alarm.
The bell outside isn't sounding either when I attach the mains and battery. Could this be a battery in the box outside that needs changing?
Any ideas?
Hold the spring tamper switch in with your finger on the control panel and reset with code.
Is the battery connected ? Is the battery old ?
Have tried doing that and it didn't make any difference. The battery is brand new (as mentioned previously) as are the fuses that are in it. One thing I didn't do is reset everything to defaults when I did the factory reset on it to get the code back to default one before I changed it again.
Ok check the bell fuse is ok as the bell tamper won’t clear if it’s blown , remove 0v at the bell and link aux volts - to TR does that clear it ?
No at the panel ...or if you have a multimeter on dc range check between bell 12+ and 0v for 13.8v approx
Sorry for the late reply. Yes that's on the lower connectors on the board 12v & 0v. 14.0v.
I did a walk test today and I gather, from the user manual I downloaded, that during the walk test it is supposed to give out a continuous tone then when a detector is triggered it interrupts the tone. What I've got is a beeping with Entry/Exit light on then Tamper light on and it switches between those two in a beeping noise not a continuous tone.
Does this mean then that the front door magnet is bust as it keeps being triggered? I've put my meter across the two tamper wires that come from the front door magnet and am getting 2.0 ohms (give or take .1 ohms either way).
Would shorting the panel tamper pins help so it's in a constant non-tamper state?
No ....you need to find the tamper shorting the pins is going to add to your problems ...post picture of pcb with what you have shorted out ...eg tamper and bell tamper
Here you go:
Ok ....looks ok . link out e/e , then put it in walk test, it should only show tamper ...now wiggle the tamper switch on the back of the pcb and hold it in ....does it go constant tone ?
Yes it does go to constant tone. then when I release the switch it starts beeping again.
That's normal? Can you hear the tamper close when the lid is in place? The spring may need stretching slightly to reach the back of the case when the lid is close (be gentle if you try to stretch it!)
Failing that, I've known 9448 tamper switches on older panels cause an issue when the lid hasn't been opened for a while and is then opened up. They sometimes need pressing in and out a few times to get them to close properly again.
Right then, I've just stretched the spring out a little and now when I put power to the box and turn it on the internal sounder sounds, I put my code in to stop the sounder and then my code again and NO TAMPER LIGHT now. Just the Green power LED is lit.
