Repeated failure of letter plate finish
22 Jan 2012
Jersey
Hi all,
My new front door 4 years ago came with a Fab & Fix NuMail letter plate.
Thing is, I've been replacing them once a year at least!! They keep corroding, starting at the edges, then spots all over.
I am close to the sea, but I'd honestly not expect such a high failure rate.
The other issue is that the door panel has been routed out for that plate, and a couple of others I have tried don't fit, and I don't fancy adjusting the aluminium clad panel to allow fitment.
Can anyone help with a solution, or validate that these letter plates are just not very good?
This one was fitted in February....
Cheers
Tim
I get the same problem with my cctv cameras pitting from the sea air and I am a mile away.
What abour cleaning off and painting using a special primer for alli you will get the odd finger nail mark but might look better.
Otherwise shop around for something like this in your size.
https://www.carlislebrass.com/grade-316-letterplates
Thanks guys, so it looks likely I'll need to get my panel removed, and cut to fit a new plate?
Urgh, this could be a pain!
Trojan hardware has a 25 year guarantee I believe
Also Sweet hardware may be worth looking into
One of them might have fittings the size you need
