Widening the light fitting hole of a glass shade?
9 Jun 2008
Europe / London
Bit of an odd question so thought this would be the best place for it!
I have an old glass globe light shade which unfortunately has a split/crack. I've managed to find a replacement which is a reasonable size match, except for the hole for the light fitting. It's a little too small at dia 4cm when it needs to be 5cm.
Can anyone give me any advice on methods for making the hole wider? I was thinking of creating a kind of large cone which I could wrap grit paper around to gradually make the hole bigger. However I've no idea where I could find a cone big enough?
Currently I'm thinking 'carefully' grinding the hole bigger using a dremel would be the easiest route? I've not attempted grinding glass though. Does anyone have any experience of this? Is it even possible?
Any advice greatly appreciated.
Hard to picture, but I'd have thought you'd have more luck modifying the light fitting to fit the new shade rather than vice-versa.
Go on ebay and buy a glass hole saw at 50mm
Normally you can get them started by going at an angle. If not drill through some plastic and use it as a guide to make your hole bigger...
Thanks for the replies everyone. @cdbe I've never even heard of a glass hole saw/bit! Thanks for that! :) I'm certainly up for giving it a go.
Go steady! Use some water. Set your drill to the lowest screwdriver torque setting so if it bites it wont break the glass.
Hole saw is intended for use on flat plain glass not curved heat treated lamp shade.
I have drilled curved bottles etc without a problem. If its heat treated / tempered glass it will just shatter, not sure if light shades are?
It would be better to shatter as its being cut than shattering on someone's head after its installed especially if its ground floor with kids causing vibrations from above?
