Adjusting metal soil pipe
yes, magnetic externally.
Perhaps 5mm thick and there were lots of sparks!
galvanised steel then, no worry about asbestos:)
I must admit when I first saw the fibres on the cutout asbestos did cross my mind but thought more likely to be off gloves or other item of clothing
Guys, I need some help with the smaller section of this soil pipe please. The bane of my life!
As seen from this image, the 110mm soil pipe then connects to this smaller grey pipe which acts as the vent. Eventually pops out of my roof.
I went to Wolsley on the weekend to get a couple of elbows and adaptor which goes from 85mm (measured externally) to 110mm and they wanted £60. This seemed extortionate!
Is there something I could do cheaply given that its only for air and will be boxed up?
I can see online suppliers for 82mm pipe but I am concerned that it may not fit when it arrives...
Do you still have some 110mm soil pipe left over?, use a bit of that and two 110mm 45 degree bends and slip the 110mm pipe
over the 3" steel pipe and seal the gap. 85mm pipe and fittings have always been more expensive than 110mm.
That's a genius suggestion! Thanks
Yes, I have 110mm pipe and will do what you have suggested. On the sealing part, can I not buy one of those rubber adaptors if they aren't too expensive?
Update: Got the two bends and had to make do with one of these an duck tape over the top. The seal seemed pretty god but I thought the duck tape would provide further protection.
